Ok I have another question, being this my first build I have nothing more than questions.
I have the case Corsair 200R for this build, this case has the SSD slots slightly below the frontal case fan, If airflow hits directly into the SSD which would be my case due to the place I positioned the SSD is it a good thing cooling wise? or is it something I should avoid and thus place the SSD in a lower slot out of the four slots?
Thanks.
https://linustechtips.com/topic/477071-ssd-position-inside-case/
It's fine :)
https://linustechtips.com/topic/477071-ssd-position-inside-case/#findComment-6392575
It'll be fine :D you can even put it with the cables at the back of a case. I have mine mounted there where there's no airflow at all lol
i5 4670k | Noctua NH0-U12S | Asus Z97M Plus | Kingston HyperX Fury 8gb | Palit GTX 980 Ti Super Jetstream 6G | Samsung 850 EVO 250gb
WD Caviar Blue 1tb | Seasonic M12II 850W | Fractal Design Define R5 | Dell U3014 1600p 30" 60Hz
Corsair K65 | Razer Orochi | Bose QuietComfort 15 | Creative SBS A350 2.1
https://linustechtips.com/topic/477071-ssd-position-inside-case/#findComment-6392579
You'll be fine. Cooling an SSD with a fan will only help it.
https://linustechtips.com/topic/477071-ssd-position-inside-case/#findComment-6392604
