CPU temps
Go to solution Solved by Shimejii,
70 degrees is fine for a stock cooler. Probably could have redone the thermal paste but 70 is just fine.
Hello
Quick question,
When playing Battlefield 3, my i3 4170 runs at 70 degrees using the stock cooler. Is this too high?
I built the pc yesterday, and I reseated the stock cooler because I thought I forgot to remove the plastic sheet under the copper (I know, dumb, there is no plastic sheet on the stock cooler).
However, I did not apply new thermal paste (the old paste was still wet, though)
Thanks,
Chav
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/476885-cpu-temps/
70 degrees is fine. I would however to look at maybe putting/getting some new thermal compound, as I do think the thermal conductivity between the cooler and the CPU have decreased, because of for example some air left in between. :)
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/476885-cpu-temps/#findComment-6390146
nope, 70C isn't too high. If your worried, get something cheap like a Cryorig C7/M9i and that'll do the job nicely.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/476885-cpu-temps/#findComment-6390149
