So I am currently building my own system.
This is my motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132566
This is my case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
I was placing the motherboard into the case as one of the steps of the build and came across a problem one of the screws would not screw, all the other screws worked fine except for just one which seemed to wobble in the hole it was placed in and not screw all the way in when using the screwdriver. What could be the problem here, I made sure I was using the correct screw here its almost as if the the space the screw goes into was too big for the screw.
Is anyone familiar with this problem? the motherboard seems secure either way since it has all other screws except just one.
Anyways just wanted to ask, this is my first build after all.
Thanks.
https://linustechtips.com/topic/476879-case-and-motherboard/
-SNIP-
If it's just one screw it won't make or break anything but just make sure it's lined up and you didn't strip the threads, if it's the center screw most of the Corsair cases have a stud that is used for aligning the board and doesn't require a screw.
https://linustechtips.com/topic/476879-case-and-motherboard/#findComment-6390115
If it's the middle hole that's not meant to screw in it's a holder
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/476879-case-and-motherboard/#findComment-6390117
I will say straight up, it's more common than not for one of the standoffs not to want to go in.
It's not a big deal at all.
Hell Paul from Paul's Hardware considers 6/9 good enough.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/476879-case-and-motherboard/#findComment-6390132
