Hi LTT forum
Just a couple of minutes ago i was playing CS on my PC ,A watercooled prodigy,when it suddenly shut down. I know what you are thinking and NO it's not a water leak, that was the first thing i checked. Now I am kinda screwed because i had a lot of important data on that PC. Now when i try to turn it on all of the fans spin and all of the pumps are running but the screen just shows pink stripes. Also one thing to note is that my peripherals are not lighting up. Does anyone have any idea what could have caused this or how to fix it??
Thanks Johannes
My setup
CPU i7 4770K 4.8 ghz 1.4V Motherboard MSI G-45z87 RAM 32gb 1600mhz hyperx ram GPU 3x Gtx 780ti Windforce GHZ edition Case NZXT Phantom 820 Storage 64gb SSD and a 500GB HDD PSU corsair ax1200i Display(s) 3x Acer S231HL Cooling h105 8 corsair af 120
https://linustechtips.com/topic/476756-computer-might-be-dead-help/
yup GPU. try the intel HD one
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
Pink stripes to me sounds like a GPU issue, maybe try booting off of iGPU
I dont think that its only a gpu issue cause since my peripherals arnt lighting up, the motherboard might be fried
My setup
If it's outputting anything to the display, then the possibility of it being the motherboard is very slim.
If the motherboard wasn't working there wouldn't be anything on the display, let alone pink bars.
As for your peripherals, worry about that later. Just try and use a different GPU if you can for the time being.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
Hi LTT forum
Thanks Johannes
What is your powersupply? do you have a second gpu two check the validity of the problem? Does your motherboard support onboard gpu. Maybe you can connect it that way. Peripherals might not be lighting up do to bios no going through.
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
I ll try putting in my gtx 650 to see if it works that way and i ll get back to you
My setup
OK so i just rebooted my computer and suddenly it boots into safe mode with pink stripes but it doesnt boot into normal win 7
My setup
