My mother needs more storage for her laptop, I asked her for all options and she wants external hard disc. It is just going to be used for photos.
WD Elements 1TB
Silicon Power 1TB A60
Transcend StoreJet 25H3 1TB
Or just find something on these sites:
-http://goo.gl/MxFQ5w
-http://goo.gl/syTP7F
https://linustechtips.com/topic/476652-external-hard-drive-recommendation/
~snip~
Hey there vpavlicevic,
WD Elements is a great simple external drive that should do the job. Since you are looking for a simple storage solution just for storing photos, it wouldn't really matter what drive you'd choose. I could also suggest checking out WD My Passport as an option that features hardware encryption compared to WD Elements Portable. Here's info on both drives:
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
Captain_WD.
:B1:
this, pretty much
