I am looking for a CPU that is good for both rendering and gaming, and that has a good value, and is AMD (if possible) since I got a new AMD motherboard just 3 weeks ago, and would hate to replace it already. I currently have a FX8320 which is great for gaming but does not do a good job at rendering.
A mix between the red and the green team
https://linustechtips.com/topic/476574-cpu-for-rendering-and-gaming/
I HIGHLY recommend intel. i5 6 or 5th gen is fine. Yes it is more but it is worth it. I have been exsperience many AMD cpu die on me in the past and on other computers
Motherboard: Asus Z97-DELUXE(NFC&WLC) ATX LGA1150 Motherboard  ($386.75 @ Amazon Canada)
Total: $686.74
Generated by PCPartPicker 2015-10-30 23:52 EDT-0400
Good for rendering and gaming? AMD? Nah.
Really though, AMD's best processor if you don't want a toaster PC (hot enough to toast bread,) is the FX-8350. I have it, and it's great for gaming/probably rendering, but I wouldn't recommend buying it these days.
Best things for rendering AND gaming are i7's and Xeons. Here's a good one if you're on a low budget: https://pcpartpicker.com/part/intel-cpu-bx80646e31231v3
This Xeon is basically an i7 with no iGPU, and it's locked. But, it costs the same as a i5 4690k.
i5 4690k
i5's are NOT good for rendering, probably as good as the 8320.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
Core i7 2600, Gigabyte GTX 570, Asus P8Z68-V LX, 16gb (4x4gb) Kingston ValueRam, CoolerMaster 600Watt PSU
If AMD, even a step up to the FX8350 isn't much of an upgrade. TBH, Intel does a better job overall in terms of CPU core performance. Processors like the 4770(k), 4790(k) (pretty much the same as 4770(k)), and even the Xeon E3 1231v3.
But,if the mobo is compatible and you're willing to wait, the AMD Zen CPUs seem to e pretty promising.
Don't be fooled by the bottom line of my sig, that is just for my travels.
So you're telling me that Gaben is no God? Enough of your foolishness.
My hardware you ask? I'm using a Dell Inspiron 3217 Notebook... With an LG 25UM57.
the FX should really be the other way around, mediocre for gaming but great for rendering (on a budget)
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Everybody says that but nobody that says it owns them.
He doesn't have the money for that. I don't think..
The Laptop:
I regret getting AMD because it uses WAYY too much power.. but one good thing from amd is that you dont have to pay for heating because the computer will warm the whole house for you......
LMAO. Same with my crappy laptop, although it's intel based.
Yeah
I live in California, so sadly I dont benefit from that sweet furnace feature.
Yeah
Yeah. Though, really, look into that Xeon I linked (https://pcpartpicker.com/part/intel-cpu-bx80646e31231v3) It would be awesome for rendering AND gaming. It has 4 cores with hyperthreading and no iGPU, but costs a good i5 in price. i7 would be around $100 USD or so more.
Oh, but you can't OC it.
The Laptop:
If possible you can always start with just overclocking. The 8320 is an 8350 at slower clock speed. Not worth buying the 8350.
I can get 60fps in a fair number of games and very rarely go under 30. Its nothing amazing but still decent.
For rendering it is almost 1:1 on render time vs video length at 1080. 10 min for a 8 min video if I remember right.
Blarg
does have a boost clock of 4.0GHz though right?
If possible you can always start with just overclocking. The 8320 is an 8350 at slower clock speed. Not worth buying the 8350.I can get 60fps in a fair number of games and very rarely go under 30. Its nothing amazing but still decent.
well you might wanna check your facts on render time, Im rendering a Cinema 4D file right now, 40 secs long, taking 30 minutes.
Total: $686.74
You absolutely do not need a $400 motherboard. That's ridiculous.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
yes, both are the same CPU die, just the non-K does not have the option to
overclock (optional) as like the K-variant and turbos to upto 4.0GHz.
the 4790K has a turbo upto 4.4GHz
Well I only really need 4GHz for rendering and Gaming.
how do you know you only need 4GHz? and the max turbo is only on one core, not
all four cores/8 threads. overclocking K CPUs removes that limitation.
for rendering, threads and core speed are needed for reduced transcode times.
Different files. Different software. Different render times. Not everything is equal.
Blarg
I have the FX-8350. In my main rig. I just wouldn't recommend it these days since there's better options for the same price.
The Laptop:
