which one of these builds is best for gaming
http://uk.pcpartpicker.com/p/1tH8t
http://uk.pcpartpicker.com/p/1tHqX
i will be using a single monitor running at 1920 by 1080P
i will be playing skyrim, crysis 3, battliefield 3 and 4 and guild wars 2
In the future i would also like to run a 3 way monitor septup
i have a budget of £760
https://linustechtips.com/topic/47656-first-build-help/
will you overclock?
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/47656-first-build-help/#findComment-632392
Pretty solid builds , only edit i would make is wait for the 9000 series to come and get a 9950 instead of the 770. Also maybe change the SSD to a samsung 840 (Evo)
Also add a Seidon 120XL liquid cooler , for 40 bucks you hae yourself an excelent cooler or get the non XL for 25 dollars if you want to cheap out.
Interested in Business and Technology
https://linustechtips.com/topic/47656-first-build-help/#findComment-632397
i will properly do a light overclock on the cpu and the gpu's'
Then get the fx 6300. you will save a litle bit and the only difference between these two processors is that the 6350 is slightly higher clocked
@Duda777 And I think that this processor will run 2 way sli/crossfire easily. it doesn't need to be a fx 8320/50 or a/better than a 3570k ;)
https://linustechtips.com/topic/47656-first-build-help/#findComment-632421
wait for the HD 9xxx series © @CoolBeans
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/47656-first-build-help/#findComment-632424
https://linustechtips.com/topic/47656-first-build-help/#findComment-632426
How much will the 9xxx series cost i have a £400/$620 GPU  price limit
If you need this system now, i've made this for you. and it's cheapper too :)
http://uk.pcpartpicker.com/p/1tO11
possible bottleneck
It won't bottleneck. I assure you that it won't bottleneck any gtx7xx, 8xx or either 9xxx gpu
https://linustechtips.com/topic/47656-first-build-help/#findComment-632446
we don't know yet but don't set a specific budget for certain parts give us a budget for the whole system and we will be able to build something for you
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/47656-first-build-help/#findComment-632447
As the others said waiting for the 9000 series from AMD should be the best course of action at the moment.
And I'm not sure the FX 6350 is worth it, considering the difference in price between that and the FX 6300. Could someone clarify this?
The fx 6350 is a overclocked version of the fx 6300
https://linustechtips.com/topic/47656-first-build-help/#findComment-632458
http://uk.pcpartpicker.com/p/1tO5Q this will max everything at 1080P and when you go triple monitor you can get a 2ND 7970 that's why I chose a 750W PSU
Finnaly. Someone who recommends a 7970 :D
https://linustechtips.com/topic/47656-first-build-help/#findComment-632474
i dont care about the case ( the cheaper the better) and i already have HDD want a higher watt psu
Ok edited http://uk.pcpartpicker.com/p/1tObP
https://linustechtips.com/topic/47656-first-build-help/#findComment-632483
Right, then. Get the FX 6300. It's better value.
A little off topic
In my country, the fx 6300 it's only 2$ more than a fx 4300 and 30$ cheaper than a fx 4350
https://linustechtips.com/topic/47656-first-build-help/#findComment-632496
i would also like the motherboard to be SLI/crossfire ready thats why i went for the ASRock
Oh yeah I  forgot the board doesn't support it. http://uk.pcpartpicker.com/p/1tOi7
https://linustechtips.com/topic/47656-first-build-help/#findComment-632505
