How big are the differences?
“It would seem that Our Lord finds our desires not too strong, but too weak. We are half-hearted creatures, fooling about with drink and sex and ambition when infinite joy is offered us, like an ignorant child who wants to go on making mud pies in a slum because he cannot imagine what is meant by the offer of a holiday at the sea. We are far too easily pleased.”
―  C.S. Lewis  :)
https://linustechtips.com/topic/476342-x264-fast-vs-slow/
Slow will look cleaner than fast. Less artifacting.
https://linustechtips.com/topic/476342-x264-fast-vs-slow/#findComment-6383612
Slow will look better, but it immensely increases render time.
Or cpu usage if talking about streaming.  :lol:
https://linustechtips.com/topic/476342-x264-fast-vs-slow/#findComment-6383650
Any idea of time difference
―  C.S. Lewis  :)
https://linustechtips.com/topic/476342-x264-fast-vs-slow/#findComment-6383782
depends on the source
Lets say 6000 bitrate on fps gameplay
―  C.S. Lewis  :)
https://linustechtips.com/topic/476342-x264-fast-vs-slow/#findComment-6383878
Fast vs slow doesn't make too big of a difference. Here is an example I made for you and how long it took to encode.
This is with a target video bitrate of 4077Kbps.
FAST (23 seconds)
SLOW (54 seconds)
Here is a screenshot comparison.
Side note: I made this using bit rate as a target, which means they will be pretty much the same size but different image quality. If you instead use RF then both files will look the same (more or less) but the one encoded with the slow setting will be smaller in size.
Also, how big the difference is will vary depending on content.
For streaming I would recommend setting it to the slowest setting you can use without starting to drop frames. For archiving I recommend you just use the placebo preset.
https://linustechtips.com/topic/476342-x264-fast-vs-slow/#findComment-6385719
