4 Years ago, the rat was a good, solid quality mouse. Then cyborg was absorbed by madcatz, and production moved to a much cheaper chinese factory line. My rat 7 does the same thing, however, my revision 1 rat 7 back from years and years ago im using right now, still going like a boss. (Yes, i have two. A very old one, and the newer broken ass one)
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/476101-rat-7-problems/#findComment-6380323
Well thats not really on the table right now
Well I'm afraid you're out of options. It's a hardware-based problem clearly and there isn't much you can do about that without sending it back to Mad Catz, assuming it's still under warranty.
https://linustechtips.com/topic/476101-rat-7-problems/#findComment-6380336
what i can say either the circuits issue
you cant do much unless you are good with electronics and circuit soldering
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/476101-rat-7-problems/#findComment-6380337
