I have the EK-XRES D5 PWM pump and res combo. The link to which --> https://shop.ekwb.com/ek-xres-140-d5-pwm-incl-pump  . It has 2 cables, one for power and the other goes in to a fan controller (i'd assume... it fits?) whenever the controller cable is plugged in to the mobo the pump will not turn on at all but when I unplug it the pump runs just fine. Why is that? i feel like if its running at full speed all the time it will wear out early.
My current Rig (Memphis) --> http://pcpartpicker.com/p/jQYWpg
https://linustechtips.com/topic/476032-ek-pump-problem/
It's a PWM controlled pump you want to make sure in the BIOS that it's setup to run at a certain speed or change that header to be PWM enabled if possible or put it onto the CPU header.
https://linustechtips.com/topic/476032-ek-pump-problem/#findComment-6379424
Alright I'll give that a shot. Im on an asus maximus gene V1 mobo. Would that normally be in the spot where I'd control fan speed?
in the BIOS that's usually the monitor page for Asus I believe, they also have a software option with AIsuite you can install to vary pump speeds and set temperature curves.
https://linustechtips.com/topic/476032-ek-pump-problem/#findComment-6379482
This is very dependent on the motherboard, my Maximum Gene VI has terrible fan control (no graphs, just plain min rpm/temp and max rpm temp where you punch in a number), basicly all AIsuite does is tell me what my temps are and the rpm stuff is running at.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/476032-ek-pump-problem/#findComment-6379986
