 im looking for the cheapest case possible with a decent handle. im looking for a tiny micro atx but a mini itx will work as well. i live in the US
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/475778-cheapest-case-with-a-handle/
380T?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Step 1. get a case
Step 2. get some metal, make it into a handle
Step 3. use bolts or welding tools to attach handle to case
Step 4. profit
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Step 1. get a case
Step 4. profit
i want a case specifically designed to be used with a handle as they are sized great for moving around
380T?
that is NOT cheap lol, and it looks bulky too
here i got you
http://lmgtfy.com/?q=Laptop
Solitaire.
75 quid is cheap...
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
i did google, not much came up
also not down to spend a grand
75 quid is cheap...
its like 130 US, not cheap for a dude in school and no job
but in all seriousness, if you want portability then just get a laptop.
as for the mini ITX case with a handle, your best bet is to add one yourself
Solitaire.
-snip-
good for bodies, not for keeping parts inside
i already have a PC, i will move it into that case
so do this: get a mini ITX case you like, and use fabric straps to wrap them around the case on both ends, and attach a fabric handle to those
Solitaire.
welp i give up. i guess i stick with lugging around a micro atx
Step 1. get a case
Step 4. profit
Step 1: Get a case
Step 2: Get Duct Tape
Step 3: Apply Duct Tape.
Lol
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
