Posted October 28, 2015 Hello everyonei have a 10 hour music channeland i want to reduce my render timeI currently render with sony vegas on a i7 4790k and 7870xt gpuwith these settings:sony mvc/avc mp4quality: preview24 fps6 mbps10 hours cost around 3-4 hours rendering time.i wanted to buy the gtx 980 ti (for gaming and rendering)Will this reduce my render time?If it doesn't is there a rendering program that's faster than vegas pro?With the same or better quality?Thanks for reading Everything Digital Link to comment https://linustechtips.com/topic/475319-render-times-and-programs-gpu-vs-cpu/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 If it's a still image change the FPS to 1 Link to comment https://linustechtips.com/topic/475319-render-times-and-programs-gpu-vs-cpu/#findComment-6369616 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 In theory it should reduce rendering times since GTX 980 has a lot of CUDA cores that can be used in sony vegas 10 or up (I think) Long live Stalin, he loves you; sing these words, or you know what he’ll do! Link to comment https://linustechtips.com/topic/475319-render-times-and-programs-gpu-vs-cpu/#findComment-6369649 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 128kbps Audio+1FPS Image = profit, anyway youtube gonna convert it to 30FPS Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier s a d b o y s 2 0 0 1 Link to comment https://linustechtips.com/topic/475319-render-times-and-programs-gpu-vs-cpu/#findComment-6369659 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Author Hello guysI have a 10 hour channeli render with sony vegas pro 13 with a: I7 4790kSapphire hd 7870 xt16 gb ramSettings:Sony mvc/avc mp4 Quality: Preview(full)24 fpsbitrate 7 mbpsOnly use cpu (because it's takes the same time to rendering as with my sapphire hd 7870xt Time it takes to render 3-4 hours and youtube processing if 4-7 hours <--- far to muchI want to buy the GTX 980 TI Will this reduce my render time?+ is there a way to reduce youtube processing time at the same time? If not:is there a program that's faster than sony vegas and has the same/better quality?Thanks for reading! Everything Digital Link to comment https://linustechtips.com/topic/475319-render-times-and-programs-gpu-vs-cpu/#findComment-6369661 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Author 128kbps Audio+1FPS Image = profit, anyway youtube gonna convert it to 30FPS i have it on 192 kbps + i use a audio spectrem With a 1280x720 image behind it example:https://www.youtube.com/watch?v=eUytz8kuvTM Everything Digital Link to comment https://linustechtips.com/topic/475319-render-times-and-programs-gpu-vs-cpu/#findComment-6369683 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 You can try Adobe Premier Pro for me it takes 20-30 minutes to render ~3 minutes 1080p 60FPS video. The render times depends how many transitions and effects you have. If you just looking in video editing might go try 980ti but have to change some files to get adobe to accept the GPU, because it officially supported. Magical Pineapples
