Hi so ive been getting crashes lately and some freeze everything for 1-2 seconds and comes back and some acculy freeze whole computer and shows 2 diffrent colors on my main it shows yellow with stripes and on my 2nd screen it shows white with stripes idk what i can do to fix but im pretty sure its my graphics card dying or something malfuctioning with it. Hopefully u can give me some ideas to test the problem or fix it somehow.  picture is attatched.
My specs
Model AMD Radeon R9 280X
Memory 3072 MB, GDDR5
Connections HDMI, DVI
processor
Model AMD FX-8350
Speed 4.2GHz - Max Turbo
Number of Cores 8 pcs - Octa Core
RAM
Model Corsair Vengeance 8192MB (8GB)
Memory type DDR3 1600MHz
Hard Drive
Size 1000 GB
Connection 7200RPM - 6Gb / s - SATA
Motherboard
Gigabyte Model 970A-DS3P
Sound Card 8-Channel High Definition Audio
Internet 10/100/1000/Mbit Gigabit LAN
USB 2.0 / USB 3.0 6 & 2
Other
Chassis Cooler Master HAF912 - Infinity Edition
Power Supply XFX Core Edition 550W - 85% efficiency - 80PLUS
DVD Burner DVD ± RW Dual-Layer
SSD: 256gb samsung 950 evo
Cpu cooler: H60 corsair
https://linustechtips.com/topic/475145-graphic-card-problem/
@Charlie1337, try to make sure it isn't overheating. Download something like GPU-Z to tell you what the temps are.
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
https://linustechtips.com/topic/475145-graphic-card-problem/#findComment-6367012
I've had something very similar happen to a 7950 previously, the chip/vram went on it and I got various errors/bsods/freezes to similar colours to what you have right there.
That particular crash was when the video driver stopped responding and couldn't re-start and I would be left with what ever colour was on my middle of my screen with the audio replaying. That would end in a crash of the system or it restarting.
Unfortunately there isn't a fix as it could happen at any time due to the chip/vram been utilized differently every time and it might not hit the corrupt/dead part of the GPU.  RMA the card with the vendor you bought it from and explain the situation. I would advice to start doing benchmarks and playing demanding games while checking your VRAM usage and general GPU usage. This helps with been able to tell them that for example BF4 over 55% usage while cause the crashes etc. Let's them get to the point straight away.
Edit: Try to downclock your core/memory by 10%, this should help for a couple of weeks until the problem get's worse. Also if this does work then 100% RMA the card.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
https://linustechtips.com/topic/475145-graphic-card-problem/#findComment-6367267
