So I just bought a new build.
Corsair air 240
Core i5 6400
Asus Z170m-PLUS
8 gb Crucial Ram
Two 120 ssd in raid 0
Geforce 750 TI
And I installed windows 10 but I seem to have alot of crashes in apps. The Big offenders are Corsair's Utility Engine for my Strafe rgb, Chrome, Steam, and Rocket League. When I try to load Steam it wont appear on the desktop. It shows in the taskbar and when I hover the mouse over I can see the preview but I cant actually get to the program.
In Chrome websites stutter, and videos crash the computer.
Any help would be appreciated, I tried reinstalling windows, update drivers for all of the things, updating bios, compatibility mode for these apps. I'm at my wits end
post-271028-0-59865900-1446004380_thumb.
https://linustechtips.com/topic/474923-graphics-issues/
I would personally leave it for half an hour, then completely reinstall windows. If that doesn't fix the problem I would probably throw my rig out the window. Then I would sue microsoft. Then I would get an even more expensive rig.
JUST KIDDING
(kinda)
Now, I can actually be some help to you. I have much the same rig as you except that I have a AMD 8350 instead of an i5 and a couple of other differences. I never have these problems, and I'm on windows 7. But I do get different graphical glitches especially with parts of the screen staying stuck from my desktop. I fix it by changing my resolution to something lower and then back again. If this doesn't fix it I would uninstall windows. Then I would reinstall windows. If that doesn't fix it I would uninstall windows. Then install windows 8 or 7. If that didnt fix it then I would go to where I bought the parts and ask for some help. Most places would be happy to.
https://linustechtips.com/topic/474923-graphics-issues/#findComment-6363886
