CPU Cooler Question
Go to solution Solved by zzenigmaxzz,
im assuming you mean this one yes this just an aftermarket fan on a heatsink... unknown which model it is since he doesn't say in the part list
edit: nvm someone asked in the comments its a Cooler Master Geminii M4
142830.b308da82500497053edab88d186f5d06.
On to the question.  Ive seen a completed build where the person added a fan for the cpu cooler but this one was facing the pc case window, my question is how do i do this?  Also, what heatsink would i get?  (i ask for a heatsink because it appeared the person had one under the fan.
Sorry if this is did not make sence.
Edited by Made In Canada
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/474849-cpu-cooler-question/
Example picture?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362875
some heatsinks are set to have air blown down on them instead of through them like this one http://pcpartpicker.com/part/noctua-cpu-cooler-nhl9a as well as most stock heat sinks
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362886
This!  Thank You.
-Made In Canada
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362903
Im on console, but its on pcpartpicker in completed builds named "Monolith".
There is a bunch, you know any of the parts?
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362905
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362909
The picture added to this post.
im assuming you mean this one yes this just an aftermarket fan on a heatsink... unkown which model it is sicne he doesnt say in the part list
^^^^^^^^^  This is what i mean.
Also, Thank You Again.
-Made In Canada
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362924
Again, Thank You!
Could you recommend one of the two?  (the noctua one you said before and the cooler master one).
-Made In Canada
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362960
Again, Thank You!
if i was gonna get one i would get the Noctua NH-C14S but i prefer tower types myself for the beefier heatsinks
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362972
Would they be that much better?  Because i would give a few degrees for the system to look smoother but not after 10 degrees, even 5 degrees i would feel slightly guilty for.  The case would be a nzxt s340.
-Made In Canada
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6362988
something like a nhd14 would have a pretty substantial decrease in temps plus with a bigger heat sink the fans have to run slower which means less noise
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6363009
That looks like a very dank PC
if only he didnt have that god ugly sli bridge
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6363053
Thank You For The Help.
One last thing, can i get in trouble for posting a pic of a pc that is not mine?
Thank You Again.
-Made In Canada
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6363091
Than You Again.
nah.. youre not using it for any kind of monetary gains so no worries
https://linustechtips.com/topic/474849-cpu-cooler-question/#findComment-6363106
