24"-27" 144Hz G-Sync Monitor?
Croum
Any one have suggestions for a 24"-27" 144Hz G-Sync Monitor for around £300?
I'm using the monitor for heavy gaming and video editing, I also want to get into making templates and stuff for websites and small companies, so I would prefer having good colour. If you have a monitor like this a photo of yours would be appreciated.
;3 - Croum
Gaming/Editing Rig: CPU - i7 4790K|GPU - GTX 970 SSC|RAM - 16GB HyperX Fury|MOBO - Z97S SLI KRAIT|HDD - 1TB Western Digital|SSD - Samsung 850 EVO 500GB|PSU - SuperNOVA G2 650W
Check out my YouTube channel and maybe subscribe if you get the time? https://www.youtube.com/channel/UCTkGuHFjcWH73lT8RqLK9TA
Check out my digital store for cool products! https://sellfy.com/Zolias
;3 - Croum
what is your budget?
My Rig: i7 5820k @ 4.5GHz / Asus ROG r9 390X / Gigabyte x99 Gaming 5P / 32GB DDR4 PNY Anarchy / 256gb m.2 / 2x 120gb SSD Raid 0 / 6TB seagate / Dual Dell 23" IPS / Logitech Orion Spark / Steelseries Rival / AKG 553 Massdrop Edition
oh sorry didn't see the title of the post
I'm not super knowledgeable about monitors but I can tell you that the G-Sync module usually adds around £150-£200 to the overall price of the monitor so I wouldn't be super hopeful.
here is a 24" 144z 1080p gsync monitor for 230 http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16824160226
It's the size of the monitor that usually brings the price down my friend, 24" G-sync probably around £300 -£350
you best bet would be to spend a little bit more (440) and get the asus rog pg278q, its 27" 1440p, 144hz, g-sync http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16824236405
fuckING french fries Watson! (any idea when the discount will end?)
newer usually doesn't end sales unless they say in the description, that is their own markdown for that monitor
newegg* not newer
sugoi
do you think it comes with a display port cable?
it does not say anywhere but you could get one on monoproce for very dirt cheap
monoprice*
thank you C:
thank you C:
no problem
27" 144hz Gsync is more like 550£
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
