Hey Guys,
I'm going to get a NZXT Phantom 410.
The following hardware will be installed in the case:
ASRock B75 Pro3 M
Intel i5 3450
Sapphire Radeon HD 6870
HDD+SSD
My current CPU cooler is a Scythe Katana 4.
I would like to run the system as quiet and cool as possible!
Which fans do you recommend? (I thought about getting the Corsair AF120 series)
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/
I don't know about the AF's but i've hear that the SP's can get quite loud and tend to make a strange sound of sorts. Noctua's are really quiet though. I have 4 in my case running on my rads and my system is whisper quiet. If you are looking for airflow fans i would recommend http://www.ncix.com/products/?sku=78186&vpn=NF-A14%20FLX&manufacture=Noctua or for 120mm fans http://www.ncix.com/products/?sku=66920
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/#findComment-628468
I've got the 410 and if you wire the stock fans into the controller they're very quiet and still work rather well.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/#findComment-628471
I would keep the stock fans tbh they push a good amount of air and are pretty quiet on 7v and 5v. I have the 2 120mm fans in the front of the case then one noctua pulling through a rad as exhaust.
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/#findComment-628473
There are 3 fans included.
- 120mm in the front, where is room for another 120mm
- 120mm rear
- 140mm on the top, where is also room for another 140mm
Should I maybe keep the stock fans and add some better ones? How should I arrange them for the best airflow?
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/#findComment-628590
Noiseblocker fans are very good and they look very nice. I would also suggest that you make the front as intakes, and don't forget to put dust filters on the front intakes, because that whole honeycomb design will get clogged up with dust.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/#findComment-630895
It does have a fan filter in the front of the case it's just not the most noticeable thing.
https://linustechtips.com/topic/47398-nzxt-phantom-410-cooling/#findComment-631996
