My first Water Cooling Loop
There are a few issues I'm having at the moment:
1 - Go with 2 dual 120mm rads with res and pump built in or go with bare bones rads, pump and res.
2 - Which Rads to get. I'm leaning towards Swiftech but there selection is limited on NCIX and non existent at any other Computer related sites I've found that sell Water cooling components in Canada. I really don't want to have to order out of the US.
3 - Which fans to use for the rads to give the best cooling.
4 - Water coolant I want the best all in one out there. I don't want to have to add a whack-load of additives to prevent issues that can arise.
Basically, I'm looking for some experienced recommendations, and hopefully someone out there has done water cooling with the CM Storm Stryker case and can share some tips etc.
1- Its always best to separate your components, makes upgrading easier and you tend to get better performance when they are separate.
2- No one radiator is better than other radiators. They differ in performance by insignificant amounts. When picking a radiator pick it based on most importantly dimensions, then looks and features. And bear in mind that although more expensive things tend to perform better as a rule of the world in radiators this performance increase is very small.
Check what your case can accept and pick the biggest rad you can fit if you want the best performance. By extension of this I will explain FPI. FPI (Fins per inch) is a measure of how many cooling fins there are in a radiator. As a rule of thumb thicker radiators have lower FPI. Low FPI is good because fans can run slower and push the same amount of air through. Slow running fans are quieter but they also mean you can ramp them up if you need it.
So pick as thick a radiator as you can get, with features you like, at as low a price as you can get when choosing radiators.
Go to the FAQ for a list of water cooling sites you should be looking to buy from.
3 - For low RPMs; Noctua NF F12s. For mid-high RPMs Scythe gentle typhoons. If you're going to run with 480mm of rad space you will be better with the typhoons.
4 - EK and XSPC coolants are among the most stable coolants for watercooling. If you want your system to last go with them. Mayhems Pastel range is best in terms of looks but is known to have issues.
