I would but i don't want to go much more over my budget... should I go for a 970 instead?
I would say that is a VERY good idea, go for either a 970 or a 390 to save a few bucks.  You have a good monitor, but with it being only 1080p, it would be overkill to get a 980.  I personally can run BF4 @ all ultra @ 1080p usually above 90FPS with my 390 and 4690k (neither are OC'd).  I would do that and then get an SSD and stick with your HDD, (again, I have a 1tb Segate in my rig for storage and a 240GB SSD for boot+ main games)
i5-4690k @ 3.5ghz - Gigabyte R9390 - MSI Z97S SLI Krait - 2x4GB S.Skill RAM @ 2400 NZXT S340 - EVGA 850W B2 -  Silicon Power S60 240GB SSD (boot + main programs) - Segate 1TB (Mass storage)
Is that how you signature?
https://linustechtips.com/topic/473774-need-pc-advice/#findComment-6348695
I am building my first PC with a lenient 1300 budget, I want any advice on parts and stuff and what to do... Thanks :D.
The List: http://pcpartpicker.com/p/k8JwBm
Now looking at the list again, we'd have very similar builds haha :)  Here's my current rig:
http://pcpartpicker.com/p/pHxfWZ
(also noting I'm picking up the Cryorig H5 in a few weeks and ditching my stock cooler)
https://linustechtips.com/topic/473774-need-pc-advice/#findComment-6348706
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($226.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.99 @ Amazon)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($125.89 @ OutletPC)
Memory: Kingston HyperX Fury White 16GB (2 x 8GB) DDR3-1866 Memory ($80.49 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($84.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.33 @ OutletPC)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card ($333.98 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case ($59.99 @ Micro Center)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($87.22 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($89.89 @ OutletPC)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor ($149.00 @ Amazon)
Total: $1319.66
Generated by PCPartPicker 2015-10-26 01:49 EDT-0400
You don't need a 980 for 1080p. A 390 will max out most games at 60fps. I added an SSD and changed the PSU.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/473774-need-pc-advice/#findComment-6348709
I'd personally go with a R9 390 8GB. You could buy a 390 + SSD instead of the 980.
https://pcpartpicker.com/parts/video-card/#sort=a8&page=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127874&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/473774-need-pc-advice/#findComment-6348714
