So I ended up buying a power supply that doesn't have an 8 pin connector for the video card. No wonder it was so cheap.
I was about to take it out, sell it and grab something else, but I noticed that there are many adapters available.
I have a choice of paying $10 for a 6 pin connector, or $4 for a 4 pin to 8 pin connector.
Besides the obvious pin difference, is there any difference power output wise? I'd rather not destroy either the PSU or worse, the graphics card.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/473622-6pin-adapter-for-gpu/
DONT DO IT
when they dont have the connector it usually means they cant handle it
Unless its for something temporary like a week of it running like that...
what psu and what gpu do you want to run off of it?
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/473622-6pin-adapter-for-gpu/#findComment-6347142
What specific power supply?
Seasonic S12-600
DONT DO IT
Replace the PSU
Sort of true. It's an older power supply apparently, and they didn't have 8 pin connectors back then.
Talked to my dad and he has apparently ran his card, heavily OC'd with one for many years.
It's a Seasonic S12-600, and I'll be running an HIS 7970.
https://linustechtips.com/topic/473622-6pin-adapter-for-gpu/#findComment-6347216
Are the last 2 pins actually providing power or are they just ground pins? I have no Idea what they're for o-o
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/473622-6pin-adapter-for-gpu/#findComment-6347251
Seasonic S12-600
nvm go for it..
https://linustechtips.com/topic/473622-6pin-adapter-for-gpu/#findComment-6347289
