Get a H97 mobo instead of the Z97 b/c you cannot overclock a i5 4460 and I would get a better PSU, a SSD, and a 390X/Fury
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344427
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($173.89 @ OutletPC)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard  ($68.89 @ OutletPC)
Storage: Crucial BX100 120GB 2.5" Solid State Drive  ($61.99 @ Adorama)
Video Card: XFX Radeon R9 390X 8GB Double Dissipation Video Card  ($383.98 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($73.99 @ Newegg)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.89 @ OutletPC)
Case Fan: Corsair Air Series AF140 Red 66.4 CFM 140mm  Fan  ($15.88 @ OutletPC)
Total: $1017.25
Generated by PCPartPicker 2015-10-25 13:09 EDT-0400
SSD :D
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344442
PCPartPicker part list: http://pcpartpicker.com/p/xPGP4D
Price breakdown by merchant: http://pcpartpicker.com/p/xPGP4D/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor  ($224.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($22.89 @ OutletPC)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($79.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($41.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($399.99 @ Micro Center)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm  Fan  ($20.99 @ Amazon)
Total: $1002.26
Generated by PCPartPicker 2015-10-25 13:10 EDT-0400
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344447
i fit a 390x, 212 EVO and the 4690k I5
great upgrade to this in the future is a 250GB SSD (they go for around $100)
Solitaire.
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344454
390x over the 980?
never saw someone saying this before... Why? I'm curious,
curious because I'm upgrading my GPU in near future and i'm deciding exactlly between 390x/980
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344462
390x over the 980?
8GB > 4GB
Solitaire.
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344465
390x over the 980?
$100~ cheaper for a little less (or was it same or more?) performance.
USEFUL LINKS:
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344469
http://pcpartpicker.com/p/Y4ZJLk
it's my own build, so i kept pretty much nothing (not saying you didn't do a good job). i changed it to a k processor, to go with a good, and cheap, overclocking mobo. the expensive cooler is there 1, for looks, and 2, for dat overclocking! so u should be good to go when it comes to overclocking. 980 is good, but i decided to sub it for an r9 390 since its a better 970 for the same price, but it also leaves a ton of money for better quality everything else.
https://linustechtips.com/topic/473378-1000-build-part-check/#findComment-6344528
