Hey Guys,
I got my new laptop yesterday (Lenovo yoga) and I have this thing called One Key Optimizer and there is an option called Conservation Mode on it, what does this do? I assumed that it doesn't damage the battery when plugged in for long periods of time.
Also is the forum being DDoSed, I had a CloudFlare thing again.
post-156336-0-62579700-1445782177_thumb.
​Nothing Screams Professional Other Than Comic Sans
My Build: http://pcpartpicker.com/p/bQVfqs
Dark Theme, GG
https://linustechtips.com/topic/473291-laptop-battery/
here: https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Conservation-Mode-in-Lenovo-Energy-Manager-plugged-in-not/ta-p/1677271
This mode  in energy manager affects the firmware on the battery, and stops the charging when it reaches 60%.
In some cases, not charging the battery to 100% constantly may improve the overall lifespan of the battery with the trade off being that you will have less run time on a charge because you are only using 60% of the battery capacity.
This setting is most often suggested for a system that is always Plugged in to the Ac adapter,
When the AC adapter is still connected and the battery reaches its charge limit, you will see a "Plugged-in not charging" message when you hover on the battery icon in the notification area.   Since the firmware is set, this should still work even if the system is off and just plugged in. "
also why do you use adblock. linus has a family to feed man
https://linustechtips.com/topic/473291-laptop-battery/#findComment-6343426
Haven't whitelisted this site yet, have on desktop. Doing now ;)
Dark Theme, GG
https://linustechtips.com/topic/473291-laptop-battery/#findComment-6343432
Hey Guys,
Whitelist the site if you're going to use adblock.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/473291-laptop-battery/#findComment-6343436
for every 10 cents he loses on this site, a sucker pays for a Vessel subscription. :^)
https://linustechtips.com/topic/473291-laptop-battery/#findComment-6343474
but we allhave 1 year free trials tho
https://linustechtips.com/topic/473291-laptop-battery/#findComment-6343710
