http://pcpartpicker.com/p/3WNP4D
these are the parts i have picked out for my first build.
anybody know any thing that might become a problem and is the psu enough for what i need??
it looks good and you can lower the PSU to like a 500 watt if you want you dont need 750. unless you are planning to upgrade later on and want it for that reason
https://linustechtips.com/topic/472981-pc-build-help/#findComment-6340095
you can go with the 550 g2 series from evga for the psu and i would get a 390 instead of the 970
also the green series are slower drives, they use less power but are a good bit slower, i would recommend the blue series
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/472981-pc-build-help/#findComment-6340136
You could go skylake instead you're spending a bit much on most of the compontents, as a 390 is a way better choice than a 970
PCPartPicker part list: http://pcpartpicker.com/p/krhyMp
Price breakdown by merchant: http://pcpartpicker.com/p/krhyMp/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($329.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.99 @ Amazon)
Motherboard: Asus H170M-PLUS Micro ATX LGA1151 Motherboard  ($103.75 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($53.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($46.67 @ Amazon)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($319.99 @ Amazon)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($39.98 @ Newegg)
Power Supply: Rosewill HIVE 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($63.00 @ Newegg)
Total: $976.36
Generated by PCPartPicker 2015-10-25 02:31 EDT-0400
https://linustechtips.com/topic/472981-pc-build-help/#findComment-6341834
I do think that's a good build, and as for the power supply, I disagree with those saying you should get a 500w-ish one. A 750w would give you extra room to upgrade, maybe if you decide to get a second gpu somewhere down the line. Also you could reuse it in future builds, which the 500w would probably be limited in
https://linustechtips.com/topic/472981-pc-build-help/#findComment-6341870
