Hey guys!
Thinking about a new build soon. I'd either be going with a 5820k or 6700k, not sure yet and an AIO Liquid Cooler. I have been looking at Corsair, Switech 240x and the Kraken x61. Possibly the AIO EKWB 360, if it's actually worth the price. Want the best AIO cooling possible for the CPU.
Back to the build though, I'd be wanting to fit a 980 Ti Hybrid in there, but I may want to try to fit 2 Hybrids if I decided to go SLI.
Though what cases would be able to accommodate at least a 240mm for the CPU and possibly 2 120mm rads for the hybrids?
Size doesn't matter, I just don't want something insanely tall. I'd love to have a big window to see inside. I want everything to run as cool as possible obviously. (Without a custom loop, I don't trust myself).
The only case I've really only looked and saw that could work is the Corsair Air 540. I think everything would fit in there, and I'd have a few extra fan spots.
Though is there a better or anything else you guys would recommend? I can give more detail if needed, but thank you in advance!
https://linustechtips.com/topic/472698-help-picking-a-case/
Phanteks Enthoo Pro/Luxe. Fits up to 420mm rad in the top, and you could fit one of the hybrids rads in the back, and the other at the bottom or on the front, depending on your HDD setup.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/472698-help-picking-a-case/#findComment-6336744
The Entho Pro is quite cool, the Mastercase Pro 5 might work out, again, depends on the storage needs
https://linustechtips.com/topic/472698-help-picking-a-case/#findComment-6336782
