A while back I downloaded SPY BOT ANTI-BEACON and it messed with Cortana which is not what I wanted.
I uninstalled it at the time. But reinstalled it and pressed undo  but it has not changed.
Basically I can't use COrtana when i want to.
Please help me fix this!  :(
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/472558-cortana-fix-please/
IS it missing the little mic icon on right of the search box now ? Everytime location is off I can't USE Cortana and the Mic icon is missing. If not what is the situation AluminumTech ?
It says it's disabled by company policy although I know that the ANIT-BEACON disabled it.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335297
I literally have enabled everything for it. Trust me I know what's required of Cortana. I have it on my phone and it runs like a charm.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335300
Try this link, it sounds like spy bot messed with the administrative policies in windows:
https://windowsforum.com/threads/how-to-properly-disable-cortana-in-microsoft-windows-10.211998/
See if it's off :)
I have an error when I try to do that. Uploaded a screenshot.
https://www.dropbox.com/s/55wmkcn9434e34e/error.PNG?dl=0
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335325
It sounds like you have the home version of 10, maybe that doesn't include Group Policy Editor. I will look.
http://www.tenforums.com/general-discussion/15421-windows-10-cannot-find-gpedit-msc.html
 I will see if there is any more info I can find and post it if I do ok ?
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335359
Ok. Well this sucks if i have to re-install windows on my laptop.
EDIT: OH MY GOD! I WILL HAVE TO REINSTALL BECAUSE F ing  MICROSOFT.
WHY IS THIS NOT ON THE "HOME" edition? Seriously!
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335360
AH. THERE MAY BE a work around after all. I'm trying a work around by manually editing the registry.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335368
sounds like your system services are modified
try changing them to defaults
It's to do with the registry.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335373
After looking at the reis
I found this on redit, just read for a bit, it's a shot in the dark, but seems some people fixed it:
https://www.reddit.com/r/windows/comments/3f2esj/cortana_is_disabled_by_company_policy_windows_10/
I know what Cortana needs! What I'm having a problem is that apost you referenced says go to HKLM when i don't have HKLM in my registry, I have HKEY.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335389
I can't add the appropriate Registry Key and value required for Cortana. It won't allow me to. So what do i do?
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335404
That's not the same place as the article that talks about group policy editor, not quite the same as going in regedit. I don't know about going into the registry and changing things.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335409
Yes but it does reference going to HKLM if you are on Home.
I figured out what HKLM was but my problem is that once  i got to the specified location i couldn't add the missing Key and value.
https://linustechtips.com/topic/472558-cortana-fix-please/#findComment-6335416
