Here's my version of your build
Please note that I changed all the parts to smaller parts, so you might want an even smaller case.
Do not use a corsair CX PSU for an overclocked build.  The PSU is the last place you wanna skimp. It's the most boring but also the most important part/
I also got built in wifi for your motherboard!
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($82.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 960 2GB Superclocked Video Card  ($189.99 @ Micro Center)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($49.99 @ NCIX US)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($96.45 @ OutletPC)
Total: $679.23
Generated by PCPartPicker 2015-10-23 12:09 EDT-0400
https://linustechtips.com/topic/472189-help-with-with-build/#findComment-6331004
Hey this is my first time building a custom compute. I have a link to a build that I have made. http://pcpartpicker.com/p/wY7hQ7. Any suggestions on any changes? My budget is around 600- 700 dollars.
Thanks,
Werewo1fe
G3258 with $125 CPU cooler..
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($113.99 @ NCIX US)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($67.98 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($49.89 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($198.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($53.99 @ SuperBiiz)
Total: $642.14
Generated by PCPartPicker 2015-10-23 12:14 EDT-0400
https://linustechtips.com/topic/472189-help-with-with-build/#findComment-6331038
Total: $679.23
This system won't able able to play current titles, plus the PSU is overkill.
https://linustechtips.com/topic/472189-help-with-with-build/#findComment-6331052
Yeah, I didn't want to change his CPU, and as for PSUs I only trust EVGA lol.
Plus, the PSU is not good. Evga's G2/GS/B2 Series PSU's are better.
https://linustechtips.com/topic/472189-help-with-with-build/#findComment-6331070
