I want to set up a laser sensor in my pc room when im finished with it. So that whenever I walk in it greets me or turns on the music. So anyway know of any sensors that I could hook up to a pc ?
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/471437-laser-motion-sensor/
Maybe an IR sensor? You could get one of these and do some DIY electronics.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/471437-laser-motion-sensor/#findComment-6321163
you could put an ir emitter and a receiver in the doorway that will turn it on when you walk in and block the ir light from reaching the receiver.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/471437-laser-motion-sensor/#findComment-6321247
