Will the corsair h110 fit on my G1 Sniper M5 Motherboard
yes the H110 supports LGA1150 motherboards (like the G1 Sniper M5)
does your case support the radiator? a lot will have dual 140 fans (prolly 15mm
fan spacing) and the H110 is a 20mm fan spacing radiator, are the ODD close
to the 140mm roof fans?
airdeano
https://linustechtips.com/topic/47133-please-help/#findComment-625298
