What do yall think? just a basic starter set up that can run games at 1080p res. with decent frame rates.
http://pcpartpicker.com/p/B7bNCJ
http://pcpartpicker.com/p/fRhsGX
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/471068-first-pc-build/#findComment-6316292
Looks good to me, although you could probably find marginally cheaper parts, but even then you're only looking at 10 or 20 bucks difference.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
https://linustechtips.com/topic/471068-first-pc-build/#findComment-6316297
@Mohenjo
Just out of curiousity, is that mobo any good?
its good OK, i mean its pretty good for a 45 dollar mobo. my grandma has it with a g3220 and its been going for quite a while
https://linustechtips.com/topic/471068-first-pc-build/#findComment-6316330
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($114.88 @ OutletPC)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($41.98 @ Newegg)
Video Card: MSI Radeon R9 380 4GB Video Card  ($209.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $559.71
Generated by PCPartPicker 2015-10-21 11:56 EDT-0400
You could do this to save some money.. but it's not too much saved :P Oh and USB3 headers :D
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/471068-first-pc-build/#findComment-6316370
Here's how you should go IMO, I would prefer getting an 8320 personally but it still should be fine.:
http://pcpartpicker.com/p/Xc72yc
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/471068-first-pc-build/#findComment-6316395
