Python dice roll help
Go to solution Solved by dom1310df,
Hello all, I am supposed to create a program in Python that gives the output of the something like this
Welcome to the dice roll simulator.
How many sides does the dice have? 4
How many times would you like to roll the dice? 3
** , 2 dots.
**** , 4 dots.
* , 1 dot.
Total value of all rolls:  7
I have been working on figuring out this code for a while.  The only guideline I'm supposed
to follow is using diceRoll = random.randint(1, diceSides) to get the final output.  However,
I can't even think of a place to start.  could anyone give me some pointers on what to do?
Any help is appreciated
-CJ
Edit: I am also supposed to do this using a while loop
OK, here's a better version, with comments explaining what's going on. Hope this helps :)
http://pastebin.com/GGmUBvbC
EDIT: You'll need to implement a way to catch the error thrown up if a user doesn't enter a number for either question, then ask the question again. You could even try and interpret when numbers are entered as words. Currently, int(raw_input("")) throws up an error for anything but a number.
EDIT 2: You didn't say whether you are using Python 2 or Python 3. My code is for Python 2. For Python 3, replace raw_input with input.
** , 2 dots.
**** , 4 dots.
* , 1 dot.
-CJ
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/470247-python-dice-roll-help/
** , 2 dots.
**** , 4 dots.
* , 1 dot.
-CJ
I'm currently studying python so I'm not that familiar with syntax. I'll try to suggest some logic(? algorithm?).
Let:
sides = number of sides
roll = number of rolls
total = total value of rolls
counter = rolls counter
diceRoll = temporary variable for values
str = string to print
//start the loop
While (counter <= roll){
  //roll the dice
  diceRoll = random.randint(1, diceSides);
  //loop to print
  for(x=1;x<=diceRoll;x++){
   //check the number of loop to see the number of * (I hope you get it)
    if(x==diceRoll){
      str = str + ", " + diceroll + " dots."
    }else{
      str = str + "*"
//print the **, 2 dots.
print str;
total = total + diceRoll;
print total;
I might have combined a few programming languages or something, but I hope you get what I'm trying to say. I've not tested that so just adjust it and test :D
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6305934
Let:
//start the loop
  //roll the dice
  //loop to print
    if(x==diceRoll){
    }else{
      str = str + "*"
print str;
print total;
Thank you for your suggestions, my main question is how do I stop the loop at a certain number of rolls. for example if the person inputs that they want to roll it 5 times how do I make the program roll it the number they input
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6306028
Assign the input to the variable roll.
count the number of loops.
modify this line (I'm not that sure about this) to limit the number of loops to the value of roll.
A little disclaimer:
I am not that knowledgeable with python. This code is not tested with any language I'm using. Please modify this to fit to the syntax and rules of python and everything.
But I'm pretty sure about the logic and flow of this process, just need some tweaks and optimization.
I hope (wish, pray) I'm guiding you to the right path :D :D :D
I am who I am.
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6306124
That does seem logical and pretty similar from what I know of java, I'll test what you gave me. Thanks again
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6306332
** , 2 dots.
**** , 4 dots.
* , 1 dot.
-CJ
You'll want something like this that I've put together just now. I'll add comments later to explain what everything does. Hope this is of use to you.
http://pastebin.com/J60NtVAA
How to create a strong password
Size does not matter; it's how you use it
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6307043
He needs to do it using while loop.
But I think what you did is better that mine.
That if-else i did on "*" printing is not needed.
I am who I am.
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6307079
** , 2 dots.
**** , 4 dots.
* , 1 dot.
-CJ
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6307739
Here's something similar to/an alternative to dom1310df's thorough example, just for the sake of showing a slightly different approach (dom's solution is about as clean as you could hope for).  It should be functionally equivalent, but it's a slightly different approach using a list to store the results of your rolls.  This makes it easy to do things like find the average of your rolls, get histogram data, etc if you so choose.  The printed output is also slightly different, just to make things line up vertically a bit nicer with the pips, and using string formatting for summing up the rolls.
This is for Python 3.  You'd have to change the print() functions to statements and change input() to raw_input() to use it with Python 2.
import randomnumsides = int(input("How many sides should the dic have? "))numrolls = int(input("How many times would you like to roll the die? "))# List of all rollsrolls = []counter = 0# Generate the list. As the list is generated, print each roll.while counter < numrolls:    rolls.append(random.randint(1, numsides))    print(rolls[-1], rolls[-1] * "*", sep="\t")    counter += 1print("Total value of all rolls is %i" %sum(rolls))
I really wanted to use some list comprehension here (generate the rolls list using rolls = [random.randint(1, numsides) for i in range(numrolls)]) but that, sadly, would have kind of made the while-loop trivial.
You could also change the while statement to while len(rolls) < numrolls, but this won't scale too nicely for a large number of rolls.  But, it's a different approach.
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6311134
This solved the problem.  Although today my professor basically gave the answer because a bunch of people complained that the directions were unclear.  Thank you all for your help!!
https://linustechtips.com/topic/470247-python-dice-roll-help/#findComment-6311662
