http://pcpartpicker.com/ca/p/w3bc I know you wanted the 7970' date=' however that Twin Frozer III 7950 has a 7970 PCB (bigger VRMS, same ram modules etc), therefore you can literally overclock it to 7970 speeds, and it is, for all intensive purposes, a 7970.[/quote']
Not overclocked though, the core speed is much lower (lower even than a stock 7850 it would seem).
Your build looks fine but, honestly, if he originally asked for an SSD, I'd give him an SSD. They are better and if he is efficient, he won't fill a 120 too quickly.
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6030
http://pcpartpicker.com/ca/p/w3bc I know you wanted the 7970' date=' however that Twin Frozer III 7950 has a 7970 PCB (bigger VRMS, same ram modules etc), therefore you can literally overclock it to 7970 speeds, and it is, for all intensive purposes, a 7970.[/quote'] Not overclocked though, the core speed is much lower (lower even than a stock 7850 it would seem). Your build looks fine but, honestly, if he originally asked for an SSD, I'd give him an SSD. They are better and if he is efficient, he won't fill a 120 too quickly.
Could you really add an SSD to that build though? I can't really see where else you could cut. Possibly the motherboard? At the end of the day, the SSD is a luxury, not a necessity.
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6059
Also the Samsung 840 comes highly not recommended compared to the superior 830 or 840 pro.
Why is this? I just picked one up on sale, seems to be fine, but I'm wondering what you're saying with this. Can't be that bad, can it?
The Crucial M4 you linked to is oudated. It's reliable, but there are better options
Also, for the graphics, why not cut it down and get a 7870? You'd save ~$100 and for 1080p gaming it's fine
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6074
I got the 8gb of ram because I am also going to be rendering videos
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6089
if you are buying a gpu like that
why in the hell are you skimping on the cpu?
-_-
you should get 2500k
idek why people say the 3570k
it sucks
it runs super hot and the 2500k can overclock WAYYYYYY higher
If I had one wish, I would ask for a big enough ass for the whole world to kiss
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6141
Why is this? I just picked one up on sale' date=' seems to be fine, but I'm wondering what you're saying with this. Can't be that bad, can it? The Crucial M4 you linked to is oudated. It's reliable, but there are better options Also, for the graphics, why not cut it down and get a 7870? You'd save ~$100 and for 1080p gaming it's fine[/quote']
The Samsung 840 has much lower write speeds.
Essentially:
Samsung 840 Read/Write: 530/130
Samsung 830 Read/Write: 520/400
You can see that the 830 write speeds are like three times better.
Why not cut down and get a 7870? My personal 7950 overclocked to 1100MHz sometimes (often) dips into the low 50s on max settings.
If you want max settings, the 7950 comes minimum, really, for 1080p.
With a 7870, you will get much lower framerate.
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6144
If you are going to render videos, you might as well get the 6300. Or the 8350 if you can!
I would still say get 4GB of RAM and just add another 4GB kit when you -can-. It's only like $20, if you find you need it, you can get it!
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6157
4gigs is stupid to get
even for gaming it just feels wrong and outdated when it is so cheap
he should just get G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6163
if you are buying a gpu like that why in the hell are you skimping on the cpu? -_- you should get 2500k idek why people say the 3570k it sucks it runs super hot and the 2500k can overclock WAYYYYYY higher
whaaaaaa?
What do you mean "way higher"? And it certainly doesn't suck when it is obviously and factually better.
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6175
whaaaaaa? What do you mean "way higher"? And it certainly doesn't suck when it is obviously and factually better.
prove it then
It is a complete rip off
Ivy bridge is a joke dude.
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6183
prove it then It is a complete rip off Ivy bridge is a joke dude.
I asked you to prove yourself, and now you're telling me to prove myself.....
Click me
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6250
I want the 8gb of RAM because i'm also going to be rendering youtube videos in hopefully 720p so I need the extra RAM
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6289
Although, I have a couple old sticks of 2gb ram that I culd put in, im just not sure if they are ddr2 or ddr3
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6297
I asked you to prove yourself' date=' and now you're telling me to prove myself..... Click me
There ya go! you just proved my point
yes the 3570k is better at stock, by a hair
also runs alot hotter, needs better heatsinks and
the 2500k can overclock WAY higher
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6372
Ideally what I like to do, is to invest in parts that are going to last me a long time - e.g case & psu, that i wont have to upgrade again for some time.
As others have pointed out the AMD build is really not good value for money, you want to be looking at the Intel core series.
Theres also no point in going an aftermarket cooler for that much $$$ just to overclock the AMD, where it will still be slower than an Intel cpu.
As far as SSD's id also recommend sticking with the newer top performing ones.
Just looking at Dim's build suggestion, his is pretty spot on.
Though you could swap out the case/psu and move to a Corsair 500w 80+ and a Fractal Design R4 case, which would be a really nice setup to last for some time - and still come in under budget :)
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6421
There ya go! you just proved my point yes the 3570k is better at stock, by a hair also runs alot hotter, needs better heatsinks and the 2500k can overclock WAY higher
The 3570K gets an 8.1 on Cinebench while the 2500K gets 7.46, and they both had an increase of 1.5ghz when OCd. Their speed is beside the fact if the newer one already has a better micro-architecture.
I never proved your point...
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6425
Through all the arguing, can someone suggest a build? xD
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6435
The 3570k can go on some CRAZY bundle deal sales that are definitely worth the money. I got a bundle deal for $300.
What'd you get?
Here's the price of the 3570k at a store by my house.
Your best bet would be to ask a friend to buy it and ship it to you or buy it if you ever visit the states.
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6492
Jarsky, I took a couple parts from your suggestion and I came up with http://pcpartpicker.com/ca/p/w4iX How is it?
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6587
The 3570K gets an 8.1 on Cinebench while the 2500K gets 7.46, and they both had an increase of 1.5ghz when OCd. Their speed is beside the fact if the newer one already has a better micro-architecture. I never proved your point...
WORLD RECORDS
2500k 5.9 ON AIR
3570k 5.4 on air
375 days ago – CPU cooler - Noctua NH-D14 and air temperature is +2 ©
https://linustechtips.com/topic/470-first-build-how-is-it/page/2/#findComment-6604
