I've spent a while trying to get a low buget build that will absolutely destroy all the others and I finally came up with this. Apologies to linus for using newegg but I just gave it the parts and it's giving me the cheapest option :s Anyways, here it is :D http://pcpartpicker.com/ca/p/vYtP
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/470-first-build-how-is-it/
If you have any suggestions, My budget is up to $900 but the closer to $800 the better.
Also, I want to keep the case no matter what, Keep the GPU and thats it. Other than that I am open to suggestions. :D
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5111
This isnt really balanced, mostly due to the GPU. I know you don't really wont to change it but with that budget you wont be able to take advantage of that card.
​You could save some money on the case, there are a lot of nice looking cases out there for 30$
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5239
What are you going to be using this for? I see a 7970 so I assume gaming? What resolution? 1080P? 2560x1600?
● Thermaltake Core P5 ● ASUS Z170-A ● Intel Core i7-6700k
● EK Supremacy EVO ● 2x 8GB GSkill Ripjaws
● EVGA GTX 770 ● Samsung 850 EVO 250GB ● XFX 750W Black Edition PSU
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5244
The TR2 600w isn't particularly great from what I've seen, I would recommend spending a bit more on a Corsair CX600 V2 or an XFX Core Edition 650w.
Also if this rig is for gaming, I would recommend going for an i5 as others have said, going with a FX6300 would be nearing a CPU bottleneck. For slightly more, an i5 3330P and ASRock H77M would work pretty well (without the aftermarket cooling in that case, since the 3330P is locked).
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5441
@andi1455 I can't afford a platinum or gold rated psu
@Delons, do you have any good suggestions for 1333 memory?
@The Scanner Darkly I want the AMD CPU because it's a six core and very overclockable and I plan on doing a lot of multitasking so I need the six-core.
@alsimoso I want this case because it looks good, has plenty of space, has cable routing gromits, and isn't too cheaply built.
@sashi I plan on doing a lot of gaming, resolution is currently 1080p but may increase as time goes on.
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5484
You want to do a lot of gaming? Then go Intel route as many suggested. i5 will do well with your multitasking needs.
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5509
The only option i have for intel is an i5 3570k because I want to be able to overclock and that cpu is out of my price range
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5520
Nice build.
CPU: Ryzen 7-3700x 4.4GHz, MB: ASUS PRIME B450M-AGPU: SAPPHIRE RX 590, RAM: 16GB Corsair 3200MHz, SSD: 480GB Kingston HDD: 2TB WD Green, CHASSIS: CoolerMaster HAF 912, PSU: CoolerMaster Thunder 700W, COOLERHyper 212 Black Edition
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5529
If the 3570k is out of your price range we can re-jig your build to accommodate it. I assume your budget is around $950? We could easily get you a 3570k and 7950/7870 for that price. What's your preference?
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5594
Go for it c:
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5627
@TheEpicCanadian I don't think you can get a 7970 gaming rig with that budget
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5630
If I can get intel, i want it.
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5634
Intel Core i5 3570k
ASUS P8Z77-M mATX
Cooler Master Hyper 212
Kingston KHX1600C10D3B1K2/16G
Fractal Design Core 1000 mATX Case
Corsair CX Series CX600 600W
Samsung 840 Series 120GB
Gigabyte Radeon HD 7950
$970
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5670
$970 is out of my price range, $900 is my max.
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5687
The closer to $800 the better
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5693
http://pcpartpicker.com/ca/p/w3bc
I know you wanted the 7970, however that Twin Frozer III 7950 has a 7970 PCB (bigger VRMS, same ram modules etc), therefore you can literally overclock it to 7970 speeds, and it is, for all intensive purposes, a 7970.
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5776
How's this, ended up landing $1 of 900 :D http://pcpartpicker.com/ca/p/w3jr
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-5883
You can't ask for high-end parts in a medium budget.
You only need 4GB of RAM, install more later if you need to for gaming, but I doubt it.
The 6300 is good, not as good as the 3570K but it IS respectable. I assume you don't intend to OC the CPU.
We need more information, also. Resolution? Intend on Xfire/SLI?
I'm assuming 1080p, and no.
This is my recommendation. Let me know if you disapprove, but I believe:
Fixed your processor. Fixed your cooler. New mobo. Cheaper but still efficient memory. Better SSD. 7950 instead of 7970.
Same case (no one likes that to change) and a better PSU (though lower power, still enough).
http://pcpartpicker.com/ca/p/w3Bu
$894.
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-6002
Intel Core i5 3570k ASUS P8Z77-M mATX Cooler Master Hyper 212 Kingston KHX1600C10D3B1K2/16G Fractal Design Core 1000 mATX Case Corsair CX Series CX600 600W Samsung 840 Series 120GB Gigabyte Radeon HD 7950 $970
Why are you giving 16GB of RAM if he wishes only to game?
Also the Samsung 840 comes highly not recommended compared to the superior 830 or 840 pro.
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-6015
How's this' date=' ended up landing $1 of 900 :D [url']http://pcpartpicker.com/ca/p/w3jr
Well you shouldn't have any overheating problems without a heatsink, cause you'll be out a PSU as well. =P
You'll have to face reality and realize you can't get a best GPU and CPU at the same time. Either get a better CPU and go for a, 7850 7870 or a 7950, or gte a lower end CPU, you can upgrade later, and a better GPU, but you'll be bottlenecked in the meantime.
https://linustechtips.com/topic/470-first-build-how-is-it/#findComment-6021
