So quickly i have realized the double d xfx cooler is a pile of dog sh** so i wanna get  an aftermarket cooler for it however as no one knows about it then im worried that no companies make a cooler for it. No watercooling pls.
http://www.aria.co.uk/SuperSpecials/Other+products/XFX+DD+Radeon+HD+7870+GHz+Edition+%28Tahiti+LE%29+2GB+GDDR5+Graphics+Card+%5BFX-787A-CNAC%5D+%2B+3+FREE+GAMES%21+?productId=55140
Above is a link to the card, its reference as you cant increase voltage
Listen if you care.
https://linustechtips.com/topic/46981-aftermarket-gpu-cooler7870xt/
Arctic makes the best aftermarket air cooling solutions in my opinion. This one also works for a 7870: http://www.amazon.com/ARCTIC-Accelero-Xtreme-7970-Cooler/dp/B0074VVK52/ref=sr_1_5?ie=UTF8&qid=1376754313&sr=8-5&keywords=arctic+accelero
I'm using that one currently on my 7950, and under load I never go above 60C and it is extremely quiet. Even at 100% fan speed it doesn't surpass the loudness of my case fan, which in itself is pretty quiet/
The installation process takes around 6 hours; but it's pretty easy. You can look up an installation guide, there are also a few YouTube videos showing the installation.
the 7870 xt was a limited card that lost support when the price of the 7950 went down.
You think you have it bad? I only have one fan on my XFX 7870.
your card is a normal 7870 non xt, but arctic probably has the best value oriented (if there is such a thing for aftermarket gpu blocks) just check the listed compatibility.
yes sure because 7870 uses a tahiti le chip, sorry but you are wrong, its a real XT. It even says it has 1536stream processors which is only with the XT cards, a normal 7870 has 1200 stream processors.
Listen if you care.
I think Artic Accelero Extreme is the one to get, better if you can remove the cooling and snap a picture of your card PCB.
uh your wrong, the only manufacturers that even made Tahiti le chips were sapphire and powercolor, can you please provide some proof? The only way i see this being possible is if someone stuck a xfx hsf shroud onto a sapphire/powercolor card (assuming it would be able to mount correctly, but tahiti chips are rotated 45 degrees anyway).
you would think someone with 3000 posts would know this
Been there, XFX did make Tahiti LE and exclusive for aria.co.uk.
Sauce
in the same thread,  :P
1267x950px-LL-21b83c38_20130414_015624.j
This is mine in case you are wondering, i wonder why you have higher bandwidth
Listen if you care.
Not mine and the guy overclocked his memory to 1500mhz if u didn't notice.
oohh didnt see that, i wonder why opencl isnt supported with that other guys card.
Listen if you care.
