it just does not load !
Solved by tautvydas,
YOU SHALL NOT LOAD ! (thumbs up if you get the reference)
Anyway , maybe try reinstalling your browser and/or check to see if you dont have extra software like some sort of block installed on your computer.
hehe nice one.
it appears it has something to do with my provider, some of friends had same problem (obv same provider). its fixed now, thanks everyone for help.
and still confused why i could access with VPN :unsure:
