760t help
Go to solution Solved by W-L,
Hey, i have the 760t but it doesnt have a dust filter, can you please send me the link to someone that sells it. Thanks.
Ps: im using po box.
Try Demciflex they have a good selection of fine meshed filters and can custom make some if needed;
http://www.demcifilter.com/c226/GRAPHITE-760T.aspx
https://linustechtips.com/topic/469705-760t-help/#findComment-6298767
