So for a long time now i have been building my pc up and have been looking to get that beast massive computer. But due to a recent change of events i need a portable pc, to go between multiple places. Now i have been looking into this for a long time now, and i have come up with some conclusions; First:Portable PCs are all about the case and allot of thought goes into that, Second: Finding parts that will still get the job done with out too much compromise.] and lastly, Third: Chose Micro ATX or Mini ITX. So through my research i have come up with two options based of two cases and two different sized motherboards, Mini ITX and Micro ATX. But the thing is that i'm not quite sure i have found everything yet or have seen all combinations. So that is why i have come here today to ask for help and thoughts on my ideas and findings:
ITX Build:
-CASE: Silverstone Sugo SG13B Mini ITX Tower Case
-CPU: i7 6700K
-GPU: Titan X
-Motherboard: Gigabyte GA-Z170N-Gaming 5 Mini ITX board
-Memory: Corsair Vengeance LPX DDR4-2133 16gb
-PSU: Corsair RM 650W 80+ Gold
-Storage: 1Tb Samsung 850 SSD
-CPU Cooler: Corsair H80i GT
PCPartPicker Link: http://pcpartpicker.com/p/VFLMkL
(Inspired By:
mATX Build:
-CASE: Xigmatek Aquila MicroATX Mini Tower Case
-CPU: i7 6700K
-GPU: Titan X
-Motherboard: Gigabyte GA-Z170MX-Gaming 5 mATX board
-Memory: Kingston HyperX Black DDR4-2133 16gb
-PSU: Corsair RM 850W 80+ Gold
-Storage: Intel 400GB PCI-E, 3TB Seagate Barracuda
-CPU Cooler: Corsair H100i GTX
PCPartPicker Link: http://pcpartpicker.com/p/2G4x3C
I thank anyone who responds and thanks to the Linus Media Group for hosting such a great community. I will Always be a fan.
Also Budget is not a worry im just looking for the most punch in a small portable case. Something that i can Destroy Every game At max.
https://linustechtips.com/topic/469702-portable-gaming-build-help/
A Nano is going to get you better performace per dollar as well as let you get a smaller case
The cooler should fit as there was a Seidon fitting in the video
I also threw in a 4k IPS free-sync display
And the PSU is 160mm I believe
PCPartPicker part list: http://pcpartpicker.com/p/MBKfbv
Price breakdown by merchant: http://pcpartpicker.com/p/MBKfbv/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($325.99 @ B&H)
CPU Cooler: Cooler Master Nepton 120XL 76.0 CFM Liquid CPU Cooler  ($84.99 @ NCIX US)
Motherboard: Gigabyte GA-H170N-WIFI Mini ITX LGA1151 Motherboard  ($115.99 @ SuperBiiz)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($83.99 @ Newegg)
Storage: Mushkin Chronos 480GB 2.5" Solid State Drive  ($138.69 @ Amazon)
Video Card: PowerColor Radeon R9 Nano 4GB Video Card  ($624.98 @ Newegg)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Rosewill 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.89 @ OutletPC)
Monitor: LG 27MU67 60Hz 27.0" Monitor  ($527.99 @ Amazon)
Total: $2021.50
Generated by PCPartPicker 2015-10-19 00:13 EDT-0400
I would recommend the mATX one, as it is a lot easier to work with (and that SSD is amazing). Also, switch out the Titan for a 980Ti, it's cheaper and performs around the same.
Welcome btw.
I was thinking the same thing about the size, i have big hands and the extra room would help.
And yes that is true, i forgot about that.
Total: $2021.50
I LOVE IT. Lol. it is an awesome build.
