Cities Skylines - Bus problem.
Hey guys, maybe someone can help me with this problem.  :unsure:
I have a problem with City: Skylines regarding buses.
I planed a route for my buses and build a bus depot. Everything workes fine so far, but as soon as one of the buses arrives the first station and the passengers are trying to enter the bus, a message pops up:
Object reference not set to an instance of an object [System.NullReferenceException]Details:No detailsSystem.NullReferenceException: Object reference not set to an instance of an object    at BusAI.UnloadPassengers (UInt16 vehicleID, .Vehicle& data, UInt16 currentStop, UInt16 nextStop) [0x00000] in <filename unknown>:0   at BusAI.ArriveAtTarget (UInt16 vehicleID, .Vehicle& data) [0x00000] in <filename unknown>:0   at BusAI.ArriveAtDestination (UInt16 vehicleID, .Vehicle& vehicleData) [0x00000] in <filename unknown>:0   at SuperBigTransport.BigBusAI.ArriveAtDestination (UInt16 vehicleID, .Vehicle& vehicleData) [0x00000] in <filename unknown>:0   at Improved_AI.CustomCarAI.SimulationStep (UInt16 vehicleID, .Vehicle& vehicleData, .Frame& frameData, UInt16 leaderID, .Vehicle& leaderData, Int32 lodPhysics) [0x00000] in <filename unknown>:0   at BusAI.SimulationStep (UInt16 vehicleID, .Vehicle& vehicleData, .Frame& frameData, UInt16 leaderID, .Vehicle& leaderData, Int32 lodPhysics) [0x00000] in <filename unknown>:0   at VehicleAI.SimulationStep (UInt16 vehicleID, .Vehicle& vehicleData, UInt16 leaderID, .Vehicle& leaderData, Int32 lodPhysics) [0x00000] in <filename unknown>:0   at TrafficManager.CustomCarAI.SimulationStep (UInt16 vehicleID, .Vehicle& data, Vector3 physicsLodRefPos) [0x00000] in <filename unknown>:0   at VehicleManager.SimulationStepImpl (Int32 subStep) [0x00000] in <filename unknown>:0   at SimulationManagerBase`2[Manager,Properties].SimulationStep (Int32 subStep) [0x00000] in <filename unknown>:0   at VehicleManager.ISimulationManager.SimulationStep (Int32 subStep) [0x00000] in <filename unknown>:0   at SimulationManager.SimulationStep () [0x00000] in <filename unknown>:0   at SimulationManager.SimulationThread () [0x00000] in <filename unknown>:0
When I click "okay" the message disappears for a second and then comes back. I can pause the game inbetween if I'm quick, delete the bus depot and the buses disappear. Then everything works normal again, but obviously I don't have any buses anymore :P
I tried to disable all mods, but the problem still occurs even without them.
It's probably highly unlikely someone knows an answer on this forum, but it's worth a try  ^_^
Thanks in advance.
https://linustechtips.com/topic/469368-cities-skylines-bus-problem/
Contact the Dev, file a error.
Did that already, but thanks :)
Is your bus route a loop? IIRC you have to have a continious loop and not just a line. But my guess is you know that already and this problem is unrelated.
Yeah, knew that a long time ago already  :D
But thanks for trying to help.
looks like an actual error with a game file, try a reinstall and submit a bug report
Does a reinstall also delete my safegames?
Bug report is already out  :)
if its on steam then not unless you tell it to. it will ask you if you want to keep save games, just say yes.
Shitty problem tho.
