Hola,
I've been looking to build my first ever PC, and I've thrown together a little something.
http://pcpartpicker.com/p/hwwdRB
Would this be able to run games like:
*Garrys Mod
*CS:GO
*DayZ
*Arma
Also, what problems would I encounter with it? I'd like to know these so I could plan to deal with them, etc.
Anything useful is appreciated, if you're going to be a twat, don't bother, thanks!
https://linustechtips.com/topic/469338-for-light-medium-gaming/
give me a min
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294353
Hola,
*Garrys Mod
*CS:GO
*DayZ
*Arma
You don't have to pay almost 100$ for Windows 10.
You can get a key for 20-25$ on eBay.
> For light - medium gaming
> Lists horribly optimized games
Since when are Arma, CS:GO and Garry's Mod unoptimized? ôo
Only DayZ sucks.
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294361
Get OS from reddit
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($70.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler  ($19.89 @ OutletPC)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard  ($52.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: Sapphire Radeon R9 285 2GB ITX COMPACT OC Video Card  ($162.98 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($28.99 @ Newegg)
Power Supply: XFX Core Edition 650W 80+ Bronze Certified ATX Power Supply  ($50.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($17.89 @ OutletPC)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Headphones: Turtle Beach Z11 Headphones  ($26.75 @ Amazon)
Total: $642.22
Generated by PCPartPicker 2015-10-18 12:27 EDT-0400
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294367
Only DayZ sucks.
Since source engine.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294381
Only DayZ sucks.
Arma rapes only one or two cores.
CSGO and Garry's Mod are on the Source engine. That engine is fucking awful.
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294385
Okay, I can understand what you mean with Arma, but the Source Engine, really?
Even the crappiest cards can achieve high frame rates on Source.
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294447
No, it's not the graphics card that limits it, it's the fact that the source engine also rapes a single thread :P
USEFUL LINKS:
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294458
Get this, and do yourself a favour and look on Craigslists for a GPU. You're gonna get way more bang for your buck buying used. I know that it's only a dual core, but at least it has an upgrade path and in the future you can get an i5, and in the meantime you can overclock the G3258 to like 4.0GHZ with the stock cooler, which is pretty good. You will need to update the bios for you motherboard, though I think Windows 10 does that automatically.
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.89 @ OutletPC)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($38.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ NCIX US)
Total: $271.08
Generated by PCPartPicker 2015-10-18 12:42 EDT-0400
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294483
But it works fine. So I don't see a problem.
Even integrated GPUs that aren't meant for such aplications can run it fine.  :)
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294518
Total: $271.08
The pentium reaaaallly is starting to struggle nowadays...
USEFUL LINKS:
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294524
get the os from reddit or g2a. look for your own monitor, keyboard/mouse, and headphones, but this should be a better build:
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($114.88 @ OutletPC)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($57.89 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB Superclocked+ ACX 2.0 Video Card  ($139.99 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: SeaSonic 350W 80+ Bronze Certified ATX Power Supply  ($41.99 @ SuperBiiz)
Total: $497.51
Generated by PCPartPicker 2015-10-18 13:03 EDT-0400
BigDay
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294590
You've never played a Source engine game in a 16:9 resolution, have you.
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294619
Yeah, I only play in 13:37  B)
No, really.. Wut?! o_o Almost everyone plays at 16:9. 1920x1080 is the most common resolution and because of that I used to play CounterStrike Source in that exact same resolution.
Or also Counter Strike: GO, or Portal 1 and 2 and there are probably quite a lot more if I could remember.
I also tried to play them in 21:9 3440x1440 which workes really well.
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294645
Still, the Source engine is pretty damn sloppy. Team Fortress 2 and CSGO shouldn't be able to chew through 1GB of RAM.
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6294928
Why not? Cities chews through almost 5GB.
1GB seems totally fine for a game like CS:GO.
You cannot expect a game to run at 300FPS on a Pentium with half a gig of ram.  :rolleyes:
https://linustechtips.com/topic/469338-for-light-medium-gaming/#findComment-6296066
