yes, it says its compatible with all their hydro coolers including the round ones
but make sure your GPU is compatible with the bracket first
https://linustechtips.com/topic/469303-corsair-gpu-aio-mount/#findComment-6293882
Not all the coolers works with the bracket.  Users on the Corsair Forums have mention purchasing the H80x cooler is not compatible with the bracket model they purchased.   Im not exactly sure which cooler is not compatible with which bracket other than to say that there is combinations of coolers and brackets which do not work together.
https://linustechtips.com/topic/469303-corsair-gpu-aio-mount/#findComment-6295540
