So I'll be starting a project in CAD soon. But I'm all out of ideas.
Last year I saw this on reddit:
And from this gif, I made one like this but in my own way.
Does anyone have any ideas on what I could make? It wont be 3D printed or anything.
Thank you!
https://linustechtips.com/topic/469237-cad-project-ideas/
That's pretty legit sir!
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293200
SolidWorks would be nice for this. but im not sure this would work in 3d as there is some overlapping going on
Edit: misread, make a simple compression jet engine
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293204
Thank you!
Slimmest computer case possible with special heat ventillation.
I would like some moving parts, an engine would be great but way to complicated for me.
I'm not sure if you read the whole post or I just suck at english, but I've already made the thing in the gif before, in SolidWorks. I'm looking for something new to do.
PC Case? (With top and front 540mm radiator support)
I would like something with moving parts, like an engine for example.
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293226
yeah misread it
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293229
Thank you!
How about this..
A computer case with modular panels that can open when you push a button.
Similar to the ROG series case I belief, which is electronic and opens the case into a computer pedestal :o.
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293231
yeah misread it
Aah, I'll look up how a compression jet engine works and looks like! Thank you!
How about this..
How about.. No computer related item? :D
Sorry..
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293242
Sorry..
Basically you have a bunch of turbines compressing air they are sucking in, and then a burn chamber where you add fuel and a spark source to ignite the mixture. then add a nozzle and you have thrust
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293253
88528G1350e3e1e77f3343a28a5480df13bec72d
Main Rig
Plex Server WIP
https://linustechtips.com/topic/469237-cad-project-ideas/#findComment-6293363
