850w is more than enough you could get away with using a 750w just go with a good brand like EVGA,Coolermaster,Corsair (But only use there AX or RM psu's),seasonic ect
None of those brands should be recommended without being specific to the model. EVGA has bad PSUs in their line up, as does Corsair and Coolermaster. None of them make the PSUs and have various quality units from different OEMs. Seasonic, Delta and Superflower are examples of manufacturers that can be recommended without models, as they don't really make any bad PSUs.
Also, Corsair's RM series aren't great. They're greatly overpriced for what they are.
https://linustechtips.com/topic/468740-power-supply/#findComment-6287225
Hi
Can anyone tell me whether a 850W coolermaster psu will be able to supply the demand of 4 x 8gb ddr ripjaws ram , 4820k intel i7, gtx 980ti and 2 x 730 intel ssd ?
Which 850W Cooler Master?
https://linustechtips.com/topic/468740-power-supply/#findComment-6287997
