so guys i have a build with a intel core i5 4690k but can i get the standard cooler what comes with the intel core i5 and when im gonna overclock because i first want to read me into overclocking but when i do can i just buy a good cpu cooler and put it in my pc
https://linustechtips.com/topic/468371-help/
Yes, you can use the stock cooler that comes with your i5. And yes, you can swap out for a better aftermarket cooler when you can afford one, if you're interested in better temps/noise and/or overclocking potential.
Sig under construction.
https://linustechtips.com/topic/468371-help/#findComment-6283240
What's your motherboard? and the cooler to get is probably going to be a Hyper 212 evo, depends on your case clearance though
https://linustechtips.com/topic/468371-help/#findComment-6283421
