4 fans 1 header
Solved by demrxz,
That is definitely unhealthy for your motherboard. You are pulling to many Amps from a socket. I would suggest purchasing a fan hub preferably NZXT. It will be using a molex connecter so it puts all the electrical stress on your PSU instead. Don't worry about upgrading PSU's these fans will not impact much. This is the fan hub I would suggest. https://www.nzxt.com/product/detail/157-GRID-V2-digital-fan-controller.html
