Help me with PC build.
Go to solution Solved by TheCaptain53,
Ok. So I rethink build and here he is:
Intel Core i5 4690k
Asus Z97-K
x2 HyperX Furry DDR3 4GB 1600
Asus Radeon R9 390 8GB STRIX OC
XFX Black Edition XTR 650W
I think its good now. What You think ?
Pretty damn good. That XFX power supply has a great score on JonnyGuru. http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=434
Should be a very strong build.
Hi there everybody.
i was thinking about future build. Here it is:
i5 4690k
Asus b85-pro
Asus Strix GTX 970 4GB
Also, I stucked on choosing right power supply. What PSU You will recomend? I was thinking about Thermaltake 630W Smart SE Modular. It's in decent price in my country, but maybe You have some of own suggestions.
Thanks for any interest.
Peace
Sorry for my low english, but I'm trying my best  ;)
| MOBO: Asus P8P67 Pro Rev 3.1 || CPU: Intel Core i7 2600K || COOLER: Thermaltake HR-02 Macho Rev. B || RAM: 2x Patriot Signature DDR3 4GB 1333MHz CL9 || GPU: Msi GeForce GTX 750 TI Oc || PSU: Ocz StealthXStream 2 600W || STORAGE: Segate Barracuda 1 TB || CASE: Corsair Carbide Series 300R |
https://linustechtips.com/topic/468297-help-me-with-pc-build/
R9 390 > GTX 970
Thermalfake PSUs are tosh - get an EVGA G2/GS 650W.
Get a Z board if you want a "K" chip.
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282100
MSI or Sapphire R9 390 will suit you better :)
A Z97 board is better off for a i5-4690k to allow for overclocking.
For the PSU, look for Any SeaSonic, any XFX, EVGA GS B2 or G2, Antec High Current Gamer.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282112
Get a EVGA/GS/G2/B2 or a SeaSonic power supply or another power supply that has Super Flower or SeaSonic as the OEM. Also I would recommend a 390 and a Z97 mobo so you can overclock. If you arn't planning on OC'ing then get a non-k CPU to save money.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282115
As @don_svetlio said, Z97 board for a 4690K, and an EVGA 550/650 GS/G2 would be a good shout.
If you're a little strapped for cash and don't mind the PSU being modular or not, the XFX TS 550W 80+ Gold is worth a look. It's based on the same platform as the 550GS, it does have the cables attached, but it is much cheaper.
The whole '390 vs 970' thing doesn't take into account features and other things, such as power consumption (a big factor in my eyes). In terms of pure performance, the 390 is faster, but not by a whole lot. It's not enough to rule out the 970 for its, subjectively, better features. The AMD series does, however, look to hold an advantage in DX12 titles, so that's definitely something worth considering.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282135
Just want to add - every Nvidia feature has an AMD counterpart - some worse than others but some are better. As for power - difference is 80W.
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282146
For an equivalent 'output', as such, that extra 80W will be displaced as heat (or whatever arbitrary factor of power consumption the 390 is using against the 970). The difference in cost due to electricity usage will be minimal, but the heat output is not.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282180
Get a EVGA/GS/G2/B2 or a SeaSonic power supply or another power supply that has Super Flower or SeaSonic as the OEM. Also I would recommend a 390 and a Z97 mobo so you can overclock. If you arn't planning on OC'ing then get a non-k CPU to save money,
EVGA PSU isn't availble in my country, but I will find something from XFX.
I want a modular power supply. I found this: XFX BLACK EDITION XTR 650W Full Modular. What You can say about that?
I heard a lot of opinion about 390 vs 970 battle, but after what You said about that, I will rethink my decision,
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282183
XFX are SeaSonic rebrands - solid PSUs all around.
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282224
Ok. So I rethink build and here it is:
Intel Core i5 4690k
Asus Z97-K
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282246
Intel Core i5 4690k
Asus Z97-K
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282273
Great. Thanks for all of Your support ( @TheCaptain53 @don_svetlio @DarkBlade2117 and @The_Stig)   ;)
As always, have a nice day everybody.
Peace.
https://linustechtips.com/topic/468297-help-me-with-pc-build/#findComment-6282302
