Best fan for a Hyper 212 Evo?
Firearm2112
I got a hyper 212 evo cooling a 4790k. I have no complaints with the cooler's performance. Keeps everything under 60 at load. However, the stock fan gets kinda loud under load.
Whats the best aftermarket fan for this cooler? Note, it has to be 120mm.
Thanks!
"slap some noctuas on it"
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
Don't know if it fits, but nf-f12.
My Rig:
CPU: Intel i7 5820K @4.3 GHz; Mobo: MSI X99A SLI Plus; Cooler: Cryorig H5 Ultimate; RAM: 16GB HyperX Fury Black; GPU: MSI R9 380 4GB; Case: Fractal Design Define R5 Black w/ Window; SSD: Samsung 850 EVO 256GB and 500GB; HDD: WD Blue 1TB; PSU: EVGA 750W P2
Peripherals:
Monitor: LG 29UM57; Headset: HyperX Cloud II; Keyboard: Gamdias Hermes Mechanical; Mouse: Zowie EC2-A
Yeah. Do that.
My Rig:
Peripherals:
Wait for LTT version.
My Rig:
Peripherals:
Thanks!
Just change the fan profile, if you run at a lower rpm the cpu might get hotter but it wont be very loud.
You can spend any amount of money on a fan, but running one at 900 rpm will never stack up to
the stock fan running at 1600 rpm in terms of performance.
Putting a 20$ fan on a 25$ cooler would be a bit strange.
Cougar Vortex can be had for about half that.
