Installing problem! Skylake
Go to solution Solved by Tedster,
So I built my new PC (VIII Hero i7 6700k)
everything went good so i hooked up a dvd drive to install windows 10 (which i downloaded from dreamspark)
I changed the boot priority and as soon as it started it says:
reboot and select a proper boot device
Why how can I get it away i tryed a lot of solutions from google but nothing works
I also tried my original windows 7 cd wich also doesn't work
Please help I am sitting here since 3 hours and i just can't get it to work -.-
Thanks
Akadis
1) The BIOS might just not want to boot from the optical drive. Have you tried flashing a USB with the ISO?
2) I had problems with DirectX on my Dreamspark install of Windows 7 and because I was using faulty RAM for the install I corrupted a few cabfiles that were needed to install directx stuff. Getting games to work might be a bit finicky, unsure because my experience is only with Windows 7.
Thanks
Akadis
https://linustechtips.com/topic/467691-installing-problem-skylake/
Thanks
Akadis
Sig under construction.
It works with the USB
