Thermal Compound
Go to solution Solved by Necrodead,
Most waterblocks tell you to do the 'X' method, but I prefer a line. You may also have to buy new thermal pads for the ram and/or VRM as they usually don't use paste for those and you can't re-use them most times.
So I want to replace the thermal compound on my GPU.  It is an AMD Radeon R9 280x.  I know it won't bring the temps down that much but I still wnat to do it.  Should I just put a line like on a CPU or should i cover it in compound.  Also, please don't put graphics card recommendations, I am planning to get a new one soon.  Thanks. :)
https://linustechtips.com/topic/467364-thermal-compound/
I think the recommended pattern for GPUs is a cross or a cross on top of a diagonal cross because of the larger size of the chip.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/467364-thermal-compound/#findComment-6270420
https://linustechtips.com/topic/467364-thermal-compound/#findComment-6270437
