CPU help
Go to solution Solved by desertcomputer,
We cant predict the future but if you dont need any m.2 and stuff you should be fine with i5 4560k.
I'm looking for a cpu for my first build. My friend told me to get the 6700k skylake because the i5 4690k i wanted to get would soon be obsolete. I'm not looking forward to paying the price of the skylake so I was wondering if there was other options I could go with or if the i5 will be around for another 2 years I will just go with that.
https://linustechtips.com/topic/467235-cpu-help/
Magical Pineapples
https://linustechtips.com/topic/467235-cpu-help/#findComment-6268975
what is m.2? like some advanced storage system, right?
Yea if you like fast storage... but PCEI storage is another option.
Magical Pineapples
https://linustechtips.com/topic/467235-cpu-help/#findComment-6269079
