Build Help Would Be Appreciated
Go to solution Solved by TheRandomness,
Ok, I've Added That Power Supply Now. Final Question, Do You Know If I Can Fit A 'Corsair H80' Or 'Corsair H100' instead Of A CPU fan & if this is Even effective?
What about this? The case is the same size just so you know but it can fit a bigger motherboard. Also, 120mm AIO. :D
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£164.99 @ Aria PC)
CPU Cooler: NZXT Kraken X31 69.5 CFM Liquid CPU Cooler (£54.89 @ Aria PC)
Motherboard: ASRock Fatal1ty Z97M Killer Micro ATX LGA1150 Motherboard (£86.52 @ Amazon UK)
Memory: Kingston HyperX Fury Red 8GB (2 x 4GB) DDR3-1866 Memory (£34.58 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£66.99 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£34.74 @ Aria PC)
Video Card: MSI Radeon R9 390 8GB Video Card (£269.99 @ Novatech)
Case: BitFenix Prodigy M Midnight MicroATX Mini Tower Case (£59.94 @ Aria PC)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply (£58.72 @ CCL Computers)
Total: £831.36
Generated by PCPartPicker 2015-10-15 00:02 BST+0100
This Is My First PC Gaming Build, & i have done some research & have put this build together. My Budget At Approx £800. I Like the idea of overclocking in future if possible.
My Parts List is on PcPartPicker Link Below. Thanks!
http://uk.pcpartpicker.com/p/yc3nD3
https://linustechtips.com/topic/466980-build-help-would-be-appreciated/
I'd go with at least a 600w PSU
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
I'd think about getting an ATX Case. It'll be way more future proof. Also You'll be able to add better graphics cards and more storage later on. As well as better airflow. Again, if anyone thinks I may be wrong, please correct me!
My Rig: CPU: i7 4790K CPU Cooler: BeQuiet Dark Rock 3 GPU: Gainward Phantom GTX 970 Motherboard: MSI Z97s SLI Krait Edition SSD1: (OS) 256GB Samsung 840 EVO SSD2: (Apps) 250GB Crucial MX200 HDD1: Old 2.5 inch 500GB (Games) HHD2: 1TB WD Blue (Photos/All other files) Case: Corsair SPEC-03 PSU: 700W BeQuiet Pure Power OS: Windows 10
My Peripherals:
Speakers: Teufel Concept C Keyboard: Cooler Master CM Storm Devastator  Mouse: Speedlink Decus LG G502 Proteus Spectrum
it's your decision :) but i'd still look for an atx case, corsair have some nice "boxes" you could use
My Peripherals:
My Peripherals:
That psu is not very good.
The H440 is a nice case, but I wouldn't call it portable.
You want a Z97 board for Overclocking. You can overclock on some B85 boards but they are not really designed for it.
Ahh Brilliant,. & Okay ill find a 600W.  are there any other recommendations? i don't understand Bottlenecks if anyone can spot any?
& thanks 'JulianT' But i fancied the idea of a small, Portable Box Out The Way.
The Coolermaster Hyper Evo 212 is a better choice for the cooler if you want a budget option. The Bitfenix Prodigy can take a cooler up to 175mm according to their website.
The 550W psu should be enough for a single card even with an overclock. If you want a bit of extra headroom then go with the 650W version of the EVGA GS.
i went away from the whole "portable" scene. Also, thanks for the advice with the motherboard.
My Peripherals:
Here is an updated version: http://uk.pcpartpicker.com/p/gbpYjX
My Peripherals:
Thanks For The Clear Advice, Is This Update More Up To Scratch? http://uk.pcpartpicker.com/p/Zw3QJx
That power supply is still pretty pants. The EVGA GS 650W seems to be out of stock everywhere for some reason.
The Bitfenix Prodigy needs a 160mm or smaller psu according to their website. I would suggest something like an Antec High Current Gamer 620W as that is bang on 160mm long.
http://www.bitfenix.com/global/en/products/chassis/prodigy/  Click on download centre for the info
http://www.antec.com/product.php?id=704775&fid=351
I came across this review of the Bitfenix case and the reviewer seems to suggest that even a 160mm psu is a struggle to fit. If you read the third paragraph He mentions it.
http://www.anandtech.com/show/5867/bitfenix-prodigy-review-the-affordable-performable-miniitx/3
Have you looked at the Phanteks Evolv ITX as an alternative ? There is a windowed version and non windowed version.
http://www.vortez.net/articles_pages/phanteks_enthoo_evolv_itx_review,1.html
As for the cooler, a H80 and H100i would both fit in the Prodigy and the Evolv.
Total: £831.36
USEFUL LINKS:
PSU Tier List F@H stats
