Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($127.98 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  (Purchased For $65.00)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($198.98 @ Newegg)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($59.99 @ Newegg)
Case Fan: Masscool BLD-12025V1R 60.0 CFM 120mm  Fan  ($7.89 @ OutletPC)
Other:  Windows 7 Professional ($21.86)
Total: $972.33
Generated by PCPartPicker 2015-10-13 16:17 EDT-0400
Thoughts...
https://linustechtips.com/topic/466667-first-build-started/
for gaming, may be better off with a 390 and a 4460
EDIT: also, thats a lot of fans
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261605
Total: $972.33
Thoughts...
Looks good, although the Hyper 212 EVO is a far superior air cooler at just a few bucks over the T4.
Could have gone with some mass storage instead of the second SSD, but everyone has different needs to address.
Not taking advantage of dual channel operation on the RAM side of things. You could always buy a second stick of the same ram, but that wouldn't be the same as a set rated to run in dual-channel, and it might just end up running in single channel.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261614
Overall it looks pretty good. Platinum may be a bit overkill but it will work. If you want to save some money you can bump it down to gold.
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261617
(purchased)
Solitaire.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261624
I agree with him 212 evo is just a few more dollars. dual channel RAM is not a must though.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261632
There's a good point. Unless you want to do some seriously CPU-intense work and are going to overclock that 4690k, the i5 4460 will hold down the fort for pretty much anything and would have let you put more money towards the graphics card- the most important component of a gaming pc. However, having a slightly better processor makes for a more well-rounded machine for tasks outside of gaming- namely video editing, rendering, streaming, and the likes.
Also, even though the coolers on both your CPU and GPU are decent, it's probably worth noting that this thing will be a jet engine under load, especially if you overclock that 4690k, which you should if you've bought it and a cooler. Those masscool fans aren't famous for being the most quiet, and since your build is still air-cooled, they're going to ramp way up- which will be loud with four in the case. Still, that bothers me a lot more than it bothers other people, and ergo, might not bother you as much.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261643
that... that was beautiful
also yeah, for OCing that CPU, 212 EVO does well, or a closed loop liquid cooler for $40 more
also, for an extra $50 Skylake + DDR4
Solitaire.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261651
i wouldve not gotten the SSDs ( gotten a 1tb hard drive) and wouldve tried to get a 390 then get an ssd later on. but thats just me
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261673
if you want the 4690k/380, do this:
http://pcpartpicker.com/p/LKQnD3
Solitaire.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261680
I with I could get the Hyper 212 EVO but it will not fit in my case.
As for the SSD, I have a 3 TB external hard drive that I will use to back up my 2 SSDs in Raid 0
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261690
Total: $972.33
Thoughts...
Go Skylake.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261699
I agree one ssd and a 1TB hard drive would probably been better
I like the Samsung 850 EVO + they are on sale quite a lot
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261706
well that takes care of that. haha
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261711
Well the problem is that right know my monitor is a 720p Samsung flat screen TV. However, all the parts that I have out in have the potental to support a R9 390 or above so at some point I plan on upgrading my graphics card and visual display all in one pop.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6261828
Getting two SSDs might be overdoing it, but getting one goes a long way, especially since hard disk drives prices are dropping about twice as fast as other computer components. It won't be long before a WD 1TB 7200RPM drive is around $35.
https://linustechtips.com/topic/466667-first-build-started/#findComment-6274923
